524td vs. Ebay turbo manifold
  • David Alejandro
    • 87
    Originally posted by zenn0ne
    I bought a complete kit everything was good except the manifold it cracked on installation I swear
    Pics of crack? imho, that is what a welder is for.... :D
    e30 x2 (1 cab) lotsa mods; e46 w/m3 front bumper + 330zhp suspension, e36/7 (z3) 3.0i :p
    • mikeedler
      • 6707
      exactly!
      I can weld anything that does crack with my welder. I have 2 324TD exhaust manifolds and still decided to go the ebay route. it looks way cooler- and with a few reinforcements works totally fine-- and I have yet to do anything to mine-- except drill it and add the wastegate tube to it. no problems.
      • lifeiskaos
        • 1709
        666fab will flow better than 524td and is more durable than ebay manifold. used ones often go for about $250. they allow you to run just about any size turbo (you will be restricted to tiny turbo with the 524td manifold)
        i had your mindset when i started my turbo m20. i thought i could use a cheap manifold, a turbo chip, with a total btudget of $1000. well a year and $3000 later, i finally finished my build with all quality parts and standalone engine management, then my piston rings took a shit.
        moral of story:
        1) triple your budget
        2) tuning is the most important part of your build
        3) dont turbo your only car
        • yberther
          • 1246
          that's good.
          Flickr
          Originally posted by Indecline06
          For some reason, when I get super duper ultra stoned... The M30 motor reminds me of big bird from sesame street.
          • lifeiskaos
            • 1709
            if you get a great tune and have a healthy engine and quality components, maybe i'd trust it as a DD, but aftermarket turbo systems are simply not as reliable. in any case, you need something to drive while you're doing the work. DIY turbo install can not be done in a weekend and you WILL have to make runs to local hardware stores or order some more parts etc. keep your options open. do a shit ton of research, save 3 times as much as you plan on spending so by the time you spend twice as much, you'll have some left over.
