My 1984 318i has a rattle/slap/knock thing going on when you first start it after it's been sitting about an 1hr or more. It goes away when the oil pressure light goes off (usually 1-2 seconds after start).
After it's been decently warmed up, it will pull to redline smooth as butter.
Once it gets fully warmed up, like 3/5-1/2 of the temp gauge, it will still pull smoothly but it is just noticeably noisier when doing so.
Am I right to suspect the timing chain tensioner/guides? Or is the engine toast (bearings/pins/etc)?
I recently did an oil change and put in 20w50 conventional.
Ideas?
Ideas?
