Question on engine swap job for m10
  • johnny102393
    • Oct 2022
    • 2
    Hey Guys a bit new to the e30 world and I could use some help!. Got a e30 from my dad before he passed away with a blown headgasket (was smoking and coolant spilled out) and a bmw shop near me said that since the car sat for a couple months with coolant most likely in the block that there would be rust in it. Also due to that, even if i did an HG job it will most likely burn oil still due to the rust, so i went and got another block to which im doing some work to it. I have in my car a head gasket kit and bottom end gasket kit from Autohaus (victor reins brand). Aside from that what would you guys recommend to replace at the same time? Can i get some good brand recommendation and where to get it at. Thank you very much.
  • Sunnyledge
    • Nov 2017
    • 221
    Is it a “bare” block or a “short” block (pistons, crank, bearings, etc installed) that you have? Age/condition? What work are you planning for the block?
