240g trans
  • e30trooper
    • 11576
    240g trans
    so yea today went for smog and couldnt pass because i had no 2nd gear, any idea what it might be? maybe my shift linkage, or syncro? b4 today i could only get into 2nd when under 3k after today no luck at all after 1st , i had to go to 1st to 3rd , driving back on teh freeway i was stuck in 5th ,after shaking it for a few mins i was able to get back in to lower gears. time for a new tranny or just go m20? this sucks bemmer fest is next week looks like im not taking that car :(
  • Jean
    • 18228
    Well, you would have to inspect your shift linkage to see if it's broken or very worn out. Could also try changing the tranny fluid, sometimes that does wonders.
    M10 5-speeds aren't hard to find nor are they expensive.
    • Joe318is
      • Sep 2005
      • 6451
      ive got one!
      Originally posted by vlad
      • e30trooper
        • 11576
        i just chnaged teh fluid to 75/90 tega syn., but this all happend after i let a friend drive the car and was shifting hard, so now yea sucks
        • e30trooper
          • 11576
          well ive been thinking, do i even want my 84....
          • RickSloan
            • 2401
            i also have one, but it sounds like your pressure plate is the fucked
            Need Illustration or Design work? www.robbiebyerly.com
            • flawdaboi407
              • Mar 2008
              • 324
              bad tranny if you ask me. My g240 did that... i also would get stuck in 5th and have to play with it for a few minutes.... then later my 2nd started to go out.
              84' 318i m30b35 swapped!
              • e30trooper
                • 11576
                yup stuck in 5th on teh freeway, then in traffic got stuck in 5th agian, sucks. Think im just going to sell the car now plus i want a 325i :D
                • Liam
                  • 753
                  260s loose 2nd often as well, kind of a whole Getrag thing.
                  I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃xS : φ(x)) → (∀xS : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
                  • e30trooper
                    • 11576
                    how much do the g240s go for? i might just pick one up and have it put in, i wanted to sell teh car an get a 325i but idk , how much do you think a junk yard might charge me for a m10 and tranny?
                    • RickSloan
                      • 2401
                      ill sell you the trans for 100 plus shipping
                      • e30trooper
                        • 11576
                        ill keep it in mind, still not sure if i just wanna sell the car for cheap and put a pay check or two for a 325i,
                        • e30trooper
                          • 11576
                          well trans issue will eb fixed picked up an g240 tonight and hopefully with be put in teh next few weeks and maybe a nicer m10 :D
