How to remover rev limiter
Turbo: 221whp/214ftlbs, MS3x flex @ 17psiComment
When did BMW use a M10 for F1?
There is a BMW Motorsports Race only engine called M12; its what was used in the 80's for mega boost F1 and e21 group5.
Notice:
DOHC head
Giant Turbo
GEAR DRIVE conversion
obviously DRY SUMP
Not really at all.
nothing at all is m10 besides remnants of a iron casting
Sent from my GT-N7100 using Tapatalk 2OBD1 M54/M52TU swap as a M50b25
you do realize its pretty much an m10 that is de-stroked, has a dohc head, and boosted? with a little mod i bet you can drop that head on.
just like saying the the s14 is not an m10 besides remnants of an iron casting...you can also drop that head on too with a little mod?Comment
The blocks were used ones, aquired from customers' cars. From BMW 1502s if memory serves.you do realize its pretty much an m10 that is de-stroked, has a dohc head, and boosted? with a little mod i bet you can drop that head on.
just like saying the the s14 is not an m10 besides remnants of an iron casting...you can also drop that head on too with a little modComment
And Highly worked; nothing closed to a stock block.
Even a subaru wrc engine is based off a stock block but fitted with internal liners that cost a fortune, nothing original is kept inside a m12 block.
Simply Bolt on a m12 head??? Not really happening; where does the dohc drive come from and dry sump?
Also the cost of m12 set.........not for r3v mortals.
