what is this?
  • e30_3I8I
    • Sep 2009
    • 305
    what is this?
    I checked my valves yesterday and they were good. I made the #1 cylinder tdc. and the distrubor was aligned with the #1 cylinder. the car just runs poorly. i press the pedal and the car barely revs on park. wats a dizzy? i know i have a vacuum problem but i cant find out how to fix it i need help and good detail so i can drive the car the way i want it.... thanks need help asap!!!
    my project
    http://r3vlimited.com/board/showthread.php?t=164374
  • Zachary
    • Sep 2009
    • 18
    wats a dizzy? distributer...
    um... prob an m10b18 right? sure its a vacuum problem?
    theres a funny ignition thin in the distributer - cant remember what its called but, under the rotor in the dizzy theres a silver or bronze disk like thing with 4 points.... see if its loose.
    • Danny
      • 14216
      Yeah that M18b18 sure does suck.
      • Holland
        • Nov 2008
        • 7212
        That must be the shitty euro version that we never got.
        Originally posted by DEV0 E30
        • Zachary
          • Sep 2009
          • 18
          um yep i meant m10b18 thnx for noticing
          • e30trooper
            • 11576
            your running lean. My car had this problem, it was the ICV. The ICV was stuck closed, I found this out with a nice sized rip in a hose under the ICV, I open the rip bigger and the rpm's went down and i gained the responce back. I fixed this by just making a custom ICV delete. By doing this the car ran smooth and rev'd fast. Check and clean the ICV. Ajust the timing and go from there. Good Luck, 3 weeks ago my car finaly took a dump and sold it. It was my fault , I left the dizzy ajustment bolt loose and it broke the rotor and a peice of metal fell under the rotor and bend the 4 pins so pretty much the dizzy was shot. So now im on the fourm as a X e30 owner lol good luck tho
            • a3ternus
              • 643
              Hm,"shitty" and "euro version" in the same sentence reffering to a BMW? :p
              N.
              Originally Posted by aaron_silva
              It is always frustrating having a harsh ride when
              you arent in the right mind set.
