automatic engine = manual transmission?
    Hey guys, i'm totally new to E30 engines/transmissions [I come from MKII Jettas/Golfs] but i'm learning [been wanting one for years]. So my friend has a 85' 318 with a dying M10. He sourced a clean automatic 84-85 [not too sure which one, i forgot what he said] 318 and asked me if the engine would bolt on to the trans. I'm absolutely not too sure, so I came here for the proper answer.
    Yes, but you'll most likely need a pilot bearing since the engine is out of automatic car. Also there were some changes in 84/85 318i cars in terms of how the vacuum lines are run etc. Better to swap the whole engine with all components over or you'll be chasing things.
      awesome, i'll toss the info over to him. Thanks Jean! I'll also tell him to take the harness and ecu as well.
