M10 head differences...
  • Cracker Red
    • Apr 2009
    • 91
    My head is cracked.
    Nearby, there is a 2.0l M10 out of a 2002 that I can buy for less than 100. Can I use this head with my dizzy/injection on the 84 318i, or is it all different?
    I hear the combustion chamber is a bit larger, but the valves are smaller on the older head...but same bore. I'm unsure about clearing the pistons though (quite a dome on these 318i pistons)
    Thanks!
  • FetusGoulash
    • Apr 2009
    • 91
    As far as I know the injector ports (or lack of them) may be an issue.
    • gone002
      • 880
      im pretty sure the injection will work
      you have to check the gears on the dizzy...some spin cw and others ccw
      02 heads use 2 row timing chains
      and e30 heads have single row
      i think i have heard of guys changing them out
      02 pistons come in two types ...bathtub and piano top type
      piano heads go w the e12 head
      and bath tub go with the 121 head
      (double check that i got that right)
      pistons from e30s have a all together differant shape
      im not sure which head they would or if they would work w an 02 head
      try 2002bmwfaq.com
      im sure its in the stickys there
      bimmerboltsandparts.com
      bring back the neeked broads!!!
      • Jean
        • 18228
        And you have the mechanical fuel pump
        • gone002
          • 880
          f#ck the mechanical fuel pump...get a carter
