Broke a rotor button. Cause? Fix? Why?
  • Jaxx_
    • Dec 2009
    • 1880
    sticky 1/4 mile track hooked so good i nearly broke two rotors. jumped timing so bad it backfired though the intake.
    here's a photo from my cell phone:
    so my question is, why the rotor button of all things? Anyone else have this happen?
  • Pinepig
    • Sep 2007
    • 1811
    Jeans car was doing that same thing on hard corners, the distributor cap was contacting the battery when the motor leaned over ( same direction as the motor would go on a hard launch ) Slide your battery as far away as you can get from the distributor and make sure that bitch is locked down. If it continues you may need to beef up that motor mount on the passenger side ( replace the damn thing, they get soft when oil soaked ).
    • Jaxx_
      • Dec 2009
      • 1880
      Good thinking. The only other thing I could think of is the torque and alignment against the distributor threw it off and it slammed into the side of the cap.
      MSnS soon so I won't have to worry about this stone age shit anymore... :D
      • gone002
        • 880
        oh no shit...
        mine did the same thing
        i ended up with two bent valves...
        bimmerboltsandparts.com
        bring back the neeked broads!!!
