Originally posted by Fidhle007
View Post
is my 85 318i supposed to suck this bad?
No, it's not supposed to suck that bad.
The raging shitbox '85 I had years ago was dog slow when I got it, but I'd had an '84 before that, so I knew it wasn't supposed to be THAT slow. I went through all the same shit you're going through with no luck. I finally threw a fuel pump at it (I might have done both, I don't remember) just as a shot in the dark, and the car woke right up. AMAZING difference.
A pump can produce enough pressure to run the car, but not put out the volume it needs for higher load/rpms. The bad fuel mileage has me second guessing that, but if you have to run wide open just to get anywhere, you might still burn a bunch of fuel just because of how inefficiently it's running. The other possibility I thought about was a plugged cat, how freely does it r3v when you're just sitting still?Last edited by kway; 05-14-2010, 07:25 PM.'84 318i - Lapisblau/Schwarz (in cryosleep)
'06 330i - Titansilber/Schwarz
Originally posted by E30_Pare View PostYea def needs a good tune up. I was getting around 20mpg driving like a grandma.
I seafoam'd, new air filter, new cap & rotor, new sparkplugs/wires, oil change. Now she runs like a champ & I'm getting about 34 highway. still need to do a vavle adjustment & see if I can sqeeze out another mpg or two.
That worked even with a 4.27 LSD! Definately better economy...
N.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally Posted by aaron_silva
It is always frustrating having a harsh ride when
you arent in the right mind set.
