Loud fuel pump
  • achillies
    • 647
    Loud fuel pump
    My external fuel pump is very loud. It isnt loose but when I put my hand on it I can feel it buzzing along. It makes so much noise I can here it in the car with the radio on. So I replaced it and still have the same noise.... a combo of a flushing fluid sound and a humming. I have solved almost every problem on this car but this is making me nuts. Suggestions...thoughts? Thanks
    03 325xiT/5
  • THE FEZMAN
    • Jun 2010
    • 89
    if you can hear it you know its working
    • slo325i
      • 417
      Your fuel pump is on its last leg. Replace your fuel filter and check your fuel pressure at engine bay.
      '89 325i - Totaled... good bye my love...
      '87 327i budget stroker - SOLD!!!
      '92 240sx - ca18det powered drift toy - SOLD!!!
      '89 325i - coupe - NEW daily
      '96 Audi A6 Quattro- Grocery getter/baby hauler
      '99 Busa - weekend wheelie monster
      • achillies
        • 647
        The pump is new, filter is new, correct pressure. THe noise just wont go away.
        03 325xiT/5
        • cjbecker
          • 43
          is it a consistant sound or does it change tone.
          1984 318i weber 38/38
          • Fusion
            • Nov 2009
            • 3658
            Could the pump be badly placed or something making it touch the tank wall or something and spreading vibrations/sound?
            • a3ternus
              • 643
              Mine is buzzing too...I d say leave it alone if its working!
              N.
              Originally Posted by aaron_silva
              It is always frustrating having a harsh ride when
              you arent in the right mind set.
              • seeker98664
                • 7
                fuel pump
                I had similar problem, turns out the transfer pump in the tank was no good, so the external pump was sucking air (starving for fuel). Mine is an 84 318. Hope that helps.
                • a3ternus
                  • 643
                  How much did you pay? Do you know the part number? Maybe 16 14 1 178 751?
                  N.
                  • simbas_e30
                    • Jan 2010
                    • 47
                    My pump also makes noise, it sounds almost whistle like.
                    • a3ternus
                      • 643
                      Changing the fuel filter helped a bit quieting down the pump.
                      Not a lot of improvement but definitely less noise.
                      N.
                      • crazyman
                        • Dec 2010
                        • 738
                        My 84 was doing the same and it all was the fuel inlet to the pump was getting clogged. On that fuel inlet nipple on the pump it has a tiny micro filter screen right at the end of nipple, all I did was clean that and no more noisy pump. Cus honestly a loud fuel pump is real annoying.
                        85 swartz/metallic 325E
                        84 alpine 325E
                        85 zinnoberot 318i/R.I.P
                        84 Bronzit 318i/sold
                        purchase feed back here=http://www.r3vlimited.com/board/show...82#post3535282
                        • Hey_You
                          • Nov 2009
                          • 963
                          Just drive at higher RPM's to drown out the noise, haha. Just kidding, my fuel pumps are quiet, but they are both new, along with the filter and FPR
                          85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
                          • crazyman
                            • Dec 2010
                            • 738
                            LOL, higher RPM always fixes any kind of engine noise :rofl:. As long as you don't have a stock exhaust hehe, cus that makes you look like a retard. :ohsnap:
                            84 alpine 325E
                            • ruppcam
                              • 188
                              Definately going to try that. Buzzing has been driving me mad
