M10 Breather Hose
  • achillies
    • 647
    M10 Breather Hose
    I am trying to get my valve cover breather hose out of my intake. I am using a hose with a small filter at the end that drops down towards the underside of the car. I want to do something a little less messy (and with less oil smell. Can I use anything else as a breather? Thanks
    Bob
    03 325xiT/5
  • Jaxx_
    • Dec 2009
    • 1880
    put a catch can inline so that you have baffles. otherwise crankcase pressure is just gonna force oil fumes out of the filter.
    a can with some steel wool works fine. don't forget to empty it everyonce and a while
    • Smelser
      • Feb 2011
      • 633
      Take a peice of metal tubing, and cut one end of it at a 90 (flat and the other end at saylike 45-60 degrees and insert that end into the exhuast, having the long end facing the upstream direction. Connect the house to your valve cover. This is called a pan evac system, thereby making a vacuum inside the engine. Pulling the pistons down and helping to seal them better.
      I will let you know how it works this summer.
      sigpic1984 318i Total conversion to a DIRT race car.
      Check out our build on facebook @ www.facebook.com/brewstermotorsports
