Can I get some help please it shouldn't be hard to answer.
I want to do a valve adjustment.
How important is it that I do it warm or cold?
When I start on first cylinder 1-3-4-2 start by putting at top dead center (Tdc)
Then check clearance number 1. Then rotate timing mark 180 degrees to do next cylinder 3.
Then rotate 180 degrees again to do cylinder 4?
By now i've rotated it to top dead center again.
So I wonder from the beginning can't I just check and adjust cylinders 1 and 4 at the same time because I think they are both at Tdc?
I don't want to rotate 180 degrees everytime I move on to the next cylinder.
Also has anyone seafoamed there 318i successfully with no bad side affects?
I wonder if it reduce the life of your engine. It may make it run better temporarily but how does the long term look like using it.
If I do use it you take the vacuum hose off the fuel pressure regulator and let it suck the seafoam 1/3 of it slowly and let it soak by turning car off and them running it again after 20 mins?
