jerking while on throttle
    Just bought a 86' 316 E30.. when I bought the car it took a very long time to start (a few tries) and I had to give it some gas for it to start. For the week that I've owned it, my friend and I have already replaced the in-tank fuel pump, fuel pressure regulator, spark plugs, new wires, cap and rotor looks new. It runs a lot better but its had a jerking issue since the day I got it. It occurs when I get on the throttle on either 2nd or 3rd gear, the car hesitates. My friend told me my cat could be clogged also.. any other ideas? Any input appreciated! thank you
    - James
    have you checked for vacuum leaks?
      I have and the idle is not too bad. Adjusted the timing on the car also but im really thinking it's a fuel issue
        I have the same issue. I replaced the rail fule pump but not the in tank pump. Im also pretty sure that my cat is shot. Thats the next thing to try. let me know if you find the problem and I will do the same
          yeah i have a crappy aftermarket CAT that the PO put on there..im going to go straight pipe soon and check your injectors too... my #4 injector is leaking.
            I have to say, I was GROSSLY MISSLEAD by the thread title!!
            god my sense of humour is WAY to weird!
            sigpic1984 318i Total conversion to a DIRT race car.
            Check out our build on facebook @ www.facebook.com/brewstermotorsports
              That would be "fapping while on throttle"
              Don't buy an e30
              They're stupid
              1989 325is Raged on then sold.
              1988 325 SETA 2DR Beaten to death, then parted.
              1988 325 SETA 4DR Parted.
              1990 325i Cabrio Daily'd, then stored 2 yrs ago.
