Ok, I have finally started pulling the motor apart for my turbo build and this is what I have come across so far. Opinions and information welcome.
Questions to come,
Symptoms: The car would smoke heavily on start up, lightly while driving, and heavily on the over run. Seemed lacking in power, and limited at RPM at 4600rpm (I think both those are down to the VW carb the previous owner fitted, not cool).
Anyways, the motor is being converted to EFI.
Ok, this is the bottom end, it seems to be in decent condition. The bores look like they might need a rebore as the cross hatching is gone.
What causes the brown ring at the top of the bores?
That head gasket looks like it's been around the park a few times! What is that coppery stuff, copper spray??
The bottom of the head, what are those marks at the very end? Looks like water channels have been welded closed or something, also there are some irregularities on some of the water galleries.
Here are some of the valves, and stem seals. I'm pretty sure this is what was causing the smoking, or am I wrong and it was blow by from the rings?
Questions to come,
