thread pitch - intake, exhaust and timing cover?
  • SA E30
    • 1248
    Hey guys in a pickle. I can't find what the thread pitch is on the above mentioned studs and bolts. Does anyone know? I don't have any nuts and bolts handy from the engine and I want to order the hardware.
    Oh, also anyonw know the pitch on the front crank bolt too?
  • Jaxx_
    • Dec 2009
    • 1880
    crank bolt is M20X1.5. It should be a 30mm nut.
    I don't know the thread pitch for the other ones.
    • SA E30
      • 1248
      On bmwfans/realoem it says the crank nut is m22.
      It also gives the all the lengths and bolt diameters but sadly not the thread pitch.
      • Jaxx_
        • Dec 2009
        • 1880
        well my m10 when i converted the crank pulley wheel to trigger fire with MS I used a m20x1.5 locking nut from mcmaster carr. I'm not really sure where you found M22 for that nut?
        • SA E30
          • 1248
          Where did you get a trigger wheel? I was going to go with batch injection just because I couldn't find a trigger wheel.
          I read about it on realoem. The crank nut that is.
          • Jaxx_
            • Dec 2009
            • 1880
            I got one from Tom at 02again.com. I'm sure he'll hate me sending you there because I had a few issues with it but he was very very helpful. I think I was one of the first E30 fitment. It all worked out okay, the main problem being the crank nut to wall clearance (a very thin walled 30mm socket needed to be found) forced me to get 2 other 30mm sockets.
            Tom has a lot of sweet MS stuff.
