Few questions about M10
  • shoguncro
    • May 2011
    • 115
    I have a m10b16 carb
    And i have b18 head freshed up with double valve springs
    so first i would like to replace rod bearing and piston bearings then i would like to put it together with a turbo
    But how many psi can handle a Stock engine
    are the m30 heads pistons beter then the oem m10 ?
    or dou you have a quality link where i can find infomation about parts used for building a m10 turbo
    thanks
  • 84driver
    • Aug 2011
    • 234
    People have reported 10-14 psi on the stock M10 internals with a good tune. Plenty of M10 turbo info all over the net... how you build it all depends on your budget.
    balticblau-metallic '84 318i 5spd 3.91 LSD
