$700 craigslist steal 1984 318i rough idle issue
  • EmTwenty
    • Sep 2011
    • 24
    Whats up r3v! So yesterday I bought a 1984 318i off craigslist for $700 bucks. I bought it knowing it had a high idle and wants to die when you put it in drive. Otherwise once its past 3k rpm it runs good. After doing some troubleshooting all day we came to the conclusion its a vacuum leak. We sprayed starter fluid on any possible leak with no avail and cleaned the IAC. We noticed that when you pump the brakes multiple times the idle dips down and it wants to die. So we think it maybe has a brake booster vacuum leak, or the check valve has gone bad. Just seeing if anyone has any suggestions on what it might be. Your input is much appreciated!
    $700 bucks at it's finest!
  • Blackout
    • Apr 2011
    • 4130
    Why EmTen EmTwenty?
    » PARTS FOR SALE
    » TRANSACTION FEEDBACK
    • Holland
      • Nov 2008
      • 7212
      I think auto is more of a concern...
      Originally posted by DEV0 E30
      • EmTwenty
        • Sep 2011
        • 24
        Haha I have a 1987 325is too. And for 700 bucks I could care less that it's automatic. It shifts so smooooth.
        • matt0300
          • 549
          My car idle dips too when I push in the breaks. Someone should chime in on that....
          • e30jake
            • Feb 2012
            • 855
            Tried the penny trick yet?
            What it feels like owning an e30:
            88 325 S50 swap in progress
            90 325ix
            • Pantless Spency
              It's McRib time!!!
              • Feb 2011
              • 7283
              AFM or ICV.
              • iamsam
                • Jun 2008
                • 174
                needs less M10 and more M42.
                • EmTwenty
                  • Sep 2011
                  • 24
                  So we did some more troubleshooting today. we noticed when you move the steering wheel left and right the idle dips down and wants to die, just like pumping the brakes. So I think just having a load on the engine at low rpms angers my m10, also inducing a misfire. I have a feeling there is a big vacuum leak somewhere. Or maybe it has a vacuum advance issue? I unplugged the vacuum advance solenoid electrical plug and nothing changed with the 2000rpm idle, you guys think maybe that's the culprit?
                  It's the electrical plug connecting to vacuum advance. Once again thanks for your 2 cents!
                  • EmTwenty
                    • Sep 2011
                    • 24
                    I haven't tried the penny trick but I cleaned the ICV and i could hear the valve moving. Also when it was running i unplugged the electrical connector and the idle went up so i don't think the ICV is my problem.
                    • irish44j
                      • 2763
                      vac leak would probably cause a high idle, not a low idle/dying.
                      have you checked the timing?
                      Stage rally/rallycross e30 build/competition journal
                      Track/street e21 build
                      visit Condor Speed Shop
                      visit Motorsport Hardware
                      [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
                      • shadowbethesda
                        • Apr 2011
                        • 369
                        Just bought the same car. Pics and mileage and more details?
                        1989 325i Cabriolet Auto
                        1990 325i Coupe Auto (sold)
                        1987 325i Cabriolet Manual (sold)
                        1989 325i Cabriolet Auto (sold)
                        1991 325i Coupe Auto (sold)
                        1991 325i Cabriolet Manual (sold)
                        1990 325i Sedan Auto (sold)
                        1984 318i Coupe Auto (sold)
                        • shadowbethesda
                          • Apr 2011
                          • 369
                          Also just out if curiosity... Can you please post a pic on the other side of the engine so we can see that all the vacuum hoses are hooked up and hooked correctly?
                          • e30jake
                            • Feb 2012
                            • 855
                            Same thing happened with mine when I first got it. It didn't run right until I stuck the penny in. Now I have to feather the throttle for a minute or two every once in a while to wait for it to warm up, but once it does it runs smooth. If none of the next few things work for you, I would still say at least see if it works.
                            90 325ix
                            • dougie30
                              • Apr 2012
                              • 1708
                              noob question...
                              could someone please explain what the penny trick is, and what it does
                              M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
