Hi Guys,
Have just signed up to this board. Been a member over on bimmersport.co.nz for some time but have come across an issue on my M10 that needs a wider audience to figure out what is happening.
Have come across these pipes that have been blocked off. There was another vacuum line that had the same thing done to it but I sorted out where that went.
Car is a 1985 318i Coupe Auto Jap import.
Issue #1
This pipe leads to a dead end and I cannot figure out where it is supposed to go.
RealOEM has the exploded view of my throttle assembly but doesn't show these two hoses. They are attached on the hidden side of the exploded view.
Issue #2
These two pipes should split and join back up again.
Like in the exploded view.
But someone has blocked one off and looks like the splitter valve (Labelled: "Reducer" #11631707723) is damaged.
Also when I put my VIN into realoem it says that none of the fuel injection options apply. I have also been told by a Euro parts supplier that the reducer part number I gave him is for LHD only (mine is RHD). What is up with that?
Just want to make sure I have got this right as I will order a new "Reducer" and put that back together.
Issue #3
An extra plug up the front by the air intake is not connected to anything and there is nowhere for it to be connected. Is there and extra something that is missing? It is on the same piece of wire as the plug that is in the air intake (I am guessing air temp sensor). The airflow meter has it's plug.
Sorry for the long and involved post with picture overkill just want to see if I can right these wrongs.
Many thanks in advance to anyone that may be able to help.
Andrew
Issue #1
Issue #2
Issue #3
Andrew
DREWLIENTE
