318 M10 parts on IE???
  • mason6556
    • Sep 2011
    • 183
    can someone please tell me were i can find parts of the 318i m10 on Ireland engineering. thank you
  • Deadskittles
    • Jul 2011
    • 140
    This?
    • E30_Pare
      • 7801
      Check my thread. Under m10 parts first page
      DREWLIENTE
      1$ PShops PM me
      • Hey_You
        • Nov 2009
        • 963
        Parts for the 318i M10 are under the 2002 parts. Things not to buy for your 318i m10 from the 2002 section are the cam, and distributor. Everything else works. (Note, if you get their dual valve springs and STEEL retainers, my machinist said that the inner spring did not fit the retainer too well, and he had to cut the retainers down to fit). You can also get m10 parts from RaceTEP
        85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
        • E30_Pare
          • 7801
          Hey u got a heads up on where u sourced your headers? Looking for a set that I can shorten so they don't sit soo low
          DREWLIENTE
          1$ PShops PM me
          • Hey_You
            • Nov 2009
            • 963
            RaceTEP header. It was about $200 shipped. I chose to have the oxygen sensor bung welded up higher on cylinder #4 (was worried about clearance issues) but thinking about it, the sensor isn't reading for the whole engine, so might be worth it to have it on the collector. On that note, I haven't had any running issues with it where it is.
            Only thing I didn't like about it, was there was a little bit of slag on the inside of the runners. I was able to clean it out no problem real quick, but it's the fact of the matter. Other than that, it's pretty good
            • E30_Pare
              • 7801
              Cool thx for the heads up
              DREWLIENTE
              1$ PShops PM me
              • Deadskittles
                • Jul 2011
                • 140
                E30 Pare, im intrigued on the 190 diesel project, do you have any info or a link to a build?
                • E30_Pare
                  • 7801
                  Nope. Project is still in its infant stage. Haven't taken pics or documented anything yet. When I pull the motor to do some work il start documenting, but for now it is a low key project.
                  DREWLIENTE
                  1$ PShops PM me
                  • Deadskittles
                    • Jul 2011
                    • 140
                    Is it the 2.2 liter or the 2.5?
                    • E30_Pare
                      • 7801
                      It's a 2.2. Not the best diesel, but I'm in it for the mpg. Only has about 60hp. I had a 87 300turbo diesel but the motor blew.
                      DREWLIENTE
                      1$ PShops PM me
                      • thebutterson
                        • 463
                        You can buy the cams from IE, just get a 2002 distributor cam gear to put on your distributor. Its the same thing all the 2002 guys do to run l-jet on their stock 2002 m10's. Here's a thread on 2002faq:
                        http://www.bmw2002faq.com/component/...ef6ed5dcf4ba7/
