M30 valves in M10?
  • kronus
    • Apr 2008
    • 13031
    M30 valves in M10?
    Has anyone heard of this working? I have some M30 valves and an M10 head, and they seem to fit fine when mocked up, but I'm not sure if the shaft lengths are the same.
    Dimensions on M10 valves: 46x8 intake, 38x8 exhaust
    Dimensions on M30 valves: 47x8 intake, 38x8 exhaust
    So if I'm reading this right and the lengths work out, M30 valves are an easy way to get +1 valve size in M10s.
    cars beep boop
  • LJ851
    • 7919
    I just measured a pair of M10 valves and they are approx 104mm long.
    Lorin
    The M30 is God's engine.
    • kronus
      • Apr 2008
      • 13031
      Thanks! I'll try to get mine measured and update this thread.
      As a note, the valves I have are M30B35 valves from a '88 635. IIRC the B35 valves are bigger than older M30 valves.
      cars beep boop
      • SkiFree
        • Jun 2011
        • 2766
        The lengths are different. Just had two of them in my hand not 5 minutes ago.
        ADAMS Autosport
        • kronus
          • Apr 2008
          • 13031
          cars beep boop
          • SkiFree
            • Jun 2011
            • 2766
            Sorry...... was like, should I or shouldn't I.
            Sent you a potentially good PM.
            ADAMS Autosport
            • kronus
              • Apr 2008
              • 13031
              As an aside, how much extra flow do +1 valves add, anyway?
              I'm sure it can be math'd out to a fairly generic formula, but I am at work..
              cars beep boop
              • SkiFree
                • Jun 2011
                • 2766
                I don't have the numbers in front of me. Generally speaking it's not worth doing unless you're going with a cam well over 300'.
                EDIT: UNLESS your going turbo, then it is beneficial to go oversize on the exhaust.
                ADAMS Autosport
                • SA E30
                  • 1248
                  I don't see why you couldn't shorten the M30 valve shafts and new grooves retaining grooves into them.
                  • kronus
                    • Apr 2008
                    • 13031
                    For completeness's sake, M30 valve lengths are 108mm intake, 109mm exhaust.
                    cars beep boop
                    • SA E30
                      • 1248
                      I'm really keen to give this a shot. I have to pull the cyl head off my m10 that is almost ready to go into the car. To open up the ports on the cyl head. So might as well try get this done.
                      • SkiFree
                        • Jun 2011
                        • 2766
                        Technically you could, but to me its not worth the risk vs cost balance. Again, I would not do the +1mm on the intake side.
                        I can maybe understand in South Africa where shipping can be a killer.
                        ADAMS Autosport
