shrick 304 cam m10 guys
  • dmjensen
    • Jan 2011
    • 804
    what do you guys set your timing at? i'm having trouble getting the car to rev past 1500 rpms at 10degrees advanced and i need to get the timing set somewhat right so i can rule out that. because im trying to get an e21 m10 swap from hell to run right so i can get rid of it. but right now its running so rich that the headers will glow red so im thinking i have a fuel managment issue. as far as i can tell they're stock injectors and a stock jetronic ecu.
    my original thought was that the afm was wrong but the numbers match to an 85 e30. my ecu i was told is matched to a 84. heres the orignial add from the engine that was bought ( i bought the e21 as an unfinished project that needed to be wired up and its turning into a nightmare. )
    this is my ecu
    i've been fucking with this thing for about half a year and i'm so close to getting it right... any help is much appreciated.
  • thebutterson
    • 463
    If the headers are glowing, it's probably lean. If you're having trouble advancing the timing, that would be why. The 310 is the right ecu for an 84, I'm pretty sure the 85's are 328. Make sure it's right distributor, those were also different for 84. I'm pretty sure the 85 ends in 096.
    • dmjensen
      • Jan 2011
      • 804
      no it's deffinteally pig rich. you can smell it hahaha.
      i'll have to check those numbers.
      • LJ851
        • 7918
        Is the distributor spinning the correct direction?
        Lorin
        The M30 is God's engine.
        • dmjensen
          • Jan 2011
          • 804
          yeah it is. the car runs smooth but wont rev up past 1500. i can advance the timing and it will but it wont rev about 800 above what ever it's idling at.
          with an oiliscope on the injectors it looks like the computer is trying to pulse the injectors properly but the pulse too much at idle and too little when being held at a "higher rpm" almost like the computer is giving it the wrong fuel pulses.
          • E30_Pare
            • 7801
            Try a different l-jet?
            DREWLIENTE
            1$ PShops PM me
            • LJ851
              • 7918
              A common mistake is to mix 318 and 2002/E21 cams and dist's. It will idle fine but when you go to rev it retards instead of advancing and generally has the exact symptoms you describe. It might be worth a second look. The dist needs to be spinning the same direction as the arrow on the outside of the dist body.
              Lorin
              • dmjensen
                • Jan 2011
                • 804
                thanks for pointing that out to me, because thats my problem.....
                anyone have a clockwise rotating m10 distributor??
                • Hey_You
                  • Nov 2009
                  • 963
                  You can swap distributor gears with a 2002, or go to Megasquirt with edis and remove the distributor all together
                  85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
                  • dmjensen
                    • Jan 2011
                    • 804
                    Thats what i had to do to get the disttibutor to match up with the cam in the first place, i never put 2 and 2 together because it wouldnt run. But now it does so i just need i different distbutor.
                    And no, megasquirt is expensive.
                    • LJ851
                      • 7918
                      You will need an E21 dist if you want it to be electronic like the 318 one you are now using. I dont have any but there is a decent E21 forum at bimmerforums that might help you find one.
                      Lorin
