No spark to coil
  • chagood8267
    • Jan 2014
    • 4
    No spark to coil
    I picked up an 85 318I to play with and it isn't getting spark to the coil at all. Can someone give me a list of things to check off that could cause it. I've been looking online for hours with no luck. Any help is abdicated. Thanks
  • chagood8267
    • Jan 2014
    • 4
    bump for help....still nothing
    • Smelser
      • Feb 2011
      • 633
      got a spare 12v coil?
      could be a coil, could be the internals of the distributor, i think computer, try them in that order
      sigpic1984 318i Total conversion to a DIRT race car.
      Check out our build on facebook @ www.facebook.com/brewstermotorsports
      • Smelser
        • Feb 2011
        • 633
        got voltage at the coil?
        12v on one of the terminals?
        • chagood8267
          • Jan 2014
          • 4
          replaced them all...ordered an ingition control moduel to try...should be here soond.
          • chagood8267
            • Jan 2014
            • 4
            didnt work....8( and no no power to the positive side of the coil at all
              Get the wiring diagrams for the car from http://wedophones.com/BMWManualsLead.htm and look to see where coil power comes from. I think it is like a 325 and comes from the ignition switch.
              • newbimmer
                • Mar 2014
                • 2
                Having same problem, get it figured out?
                Having same problem.
                Get it figured out yet?
                Thanks
                • hahaitzskippy
                  • Oct 2012
                  • 116
                  i went through the entire system and the last thing i got to do is the DME.
                  check my thread if you like, maybe it might help
                  my car died suddenly on the road, so i thought it was the dizzy because i was getting no spark, replaced it, it worked for 1 day and it died again, then i checked the coil, the specs were a little off but i decided to get a new coil anyways, car fired up and worked for a day before dying again... i said screw it, so i replaced the ICM as well and fuel pump and fuel pressure regulator, cleaned the injectors.
                  then now, my fuel relay buzzes so i replaced that with a new one too...
                  ok with all these new parts, my car FIRES UP but doesnt stay on... it dies right after.
                  so i am now guessing it could be a DME issue, something is not trigger the DME to feed fuel data and voltage or whatever.
                  chagood - for you to test the coil, you have to test resistance between the middle terminal and the negative, and the positive terminal and the negative.
                  it should be near spec as mentioned the bentley.
                  if you are not sure how to do it, your local autoparts store should be able to help you test to see whether the coil is within spec or not too
                  if the coil is in order, then i would suspect it would be the dizzy.
                  if you replaced the dizzy, then there is a voltage issue, your ignition system is not getting enough power to produce a spark, check the lines and harnesses to make sure all the lines are continuous.
                  if everything checks out, i am out of ideas
                  2007 Mazda CX-7 (red TURBO!!)
                  1985 BMW 318i.... beige!
                  2007 Suzuki GSX-R 600 (red)
                  previous cars
                  1) 1994 Isuzu Trooper (blue)
                  2) 2005 Scion tC (panda w/ CF)
                  3) 2001 Toyota Avalon (silver)
                  4) 1988 Nissan Pulsar XE (T top in red)
