Outside Air Temp Sensor - What does it do?
  • KI4UJO
    • Jun 2011
    • 642
    So, I noticed that on my e30, this part is destroyed. However, I'm not quite sure exactly what it controls. It is part# 12621286074, and is listed as an Outside Air Temperature Sensor. It is this :
    Any ideas? I really don't want to pay $60 for this thing at all, but m10 still doesn't idle right and everything else checks good, including the vacuum system.
    IMG_0145 by Jonathan Martin, on Flickr
  • JTDay
    • Dec 2009
    • 521
    You need it. http://www.obd-codes.com/p0110
    Although it's probably only one of a number of things causing poor idle.
    Past: 1987 325iS, Bilsteins - HR Sports
    Present: 1999 M3, Koni Yellows - HR Sports - GC Camber Plates - UUC Swaybars - UUC SSK - AFE Intake - Stromung Catback
    2009 Mazdaspeed3, Short Ram Intake - Turbo Inlet Pipe - 2nd cat Delete - Catback - Fuel Pump Internals - Cobb Accessport - Stratified E30 tune - 294/342 - SPC Camber Arms - CPE Rear Motor Mount
    • arnoldgtr
      • Mar 2004
      • 153
      It's $39 here:
      http://www.bmwmercedesparts.com/part...&siteid=215771
      John
      88 ///M3 Cinnabar
      84 318i Black
      • Jaxx_
        • Dec 2009
        • 1880
        interesting enough, when I had L-Jet in the car, the barometer and air temp sensor were no where to be found, but the car idled well.
