ok i have been researching and testing for a while and i am coming to a dead end.
replaced parts:
fuel relay (no more buzzing)
idle stabilzation relay
ICM
distributor
ignition coil
spark plugs
leads
fuel pump (secondary)
battery
tested areas:
there is spark (it also starts)
throttle open does not keep the engine going, the car still dies
MAF is good, voltage responds well with opening and closing
voltage to both fuel pumps 11-12v
fuel pressure entering the fuel rail is 43psi
compression on each cylinder is 150psi
checked all the harnesses for power and continuity (all checks out)
again, the fuel pump primes, cranks, fires up, but then just dies. it does not stay running.
we did a few test on the DME to see if there is resistance and continuity and they seem to check but i am not sure if we checked correctly
does anyone have any idea what problem i might have or test i did not do? i might have missed mentioning some.
and can someone help me lead me in the right direction on how to test your DME?
thanks in advance
update:
the car just happens to magically work now... what had happened was after all said parts aboved were replace and checking all the vacuum hoses were connected, the car would fire up and die... until suddenly a magical mechanic happened to helped me.
he found an unplugged vacuum line (ICV back into the intake boot). put that thing back and and it fired up fine. adjusted the timing by ear. all is good.
except, the car is now running rich (At least thats what the mechanic who helped me said)... a lot of smoke. maybe because the car hasnt been fired up in months.
i will let the car run again this weekend and warm up. maybe i can get this thing running again.
replaced parts:
ICM
distributor
ignition coil
spark plugs
leads
battery
tested areas:
thanks in advance
update:
