Hi, new to the forum.
Just bought a clean 1985 BMW 318i 2door that is not running. Body is clean, appears to be original (tan) paint, not signs of collision damage, interior is good for age and hardly any rust.
Installed new battery, has fuel and fuel pressure, cranks but won't fire. Jumped 12 volts to + side of coil, will start and run... sounds good until you remove jumper lead to coil, then dies. Sounds like not getting 12 volts from ignition switch to coil?? Any ideas, checked fuses.... seem OK, any relays or circuit breakers that might be oxidized that I could check. Car has been sitting no run for two or three years.
Thanks
Thanks
