I really need to buy a Bentley/Hanes manual but from what information I have found online I need to find tdc cylinder 1. Adjust distributor to get the line on the edge of it to line up with the rotor. Does that sound correct? I pulled the plugs to inspect them and they were e3 spark plugs and they were extremely fouled. I picked up a set of Bosch copper plugs and they are now gapped to .25
How do I set up the distributor correctly
You've got the right start. With #1 at TDC the center of the rotor should line up with the mark on the distributor. At this point the vacuum canister should also be facing the fuse box or the drivers side strut. The firing order is 1 3 4 2, so when you put the cap back on #1 goes where the rotor is pointing and the rest go in firing order counter clockwise. From there you can unplug the vacuum line to the distributor, get the engine warm and advance the timing to your liking or to factory specs. -
It sounds to me like you do not have the distributor timed correctly, especially if the vacuum canister plug is facing the front of the car. Did you verify that the engine was at TDC and then also check to make sure the rotor was facing the #1 plug?Comment
not all distributors spin the same way. make sure you know which way your dizzy is spinning before you plug your leads.You've got the right start. With #1 at TDC the center of the rotor should line up with the mark on the distributor. At this point the vacuum canister should also be facing the fuse box or the drivers side strut. The firing order is 1 3 4 2, so when you put the cap back on #1 goes where the rotor is pointing and the rest go in firing order counter clockwise. From there you can unplug the vacuum line to the distributor, get the engine warm and advance the timing to your liking or to factory specs.2007 Mazda CX-7 (red TURBO!!)
1985 BMW 318i.... beige!
2007 Suzuki GSX-R 600 (red)
previous cars
1) 1994 Isuzu Trooper (blue)
2) 2005 Scion tC (panda w/ CF)
3) 2001 Toyota Avalon (silver)
4) 1988 Nissan Pulsar XE (T top in red)Comment
i think the most important question is
how do you determine TDC if there are no markings on your pulley and the dizzy was previously tampered with?2007 Mazda CX-7 (red TURBO!!)
previous cars
There's a mark on the cam that will line up with a boss on the head that is directly beneath the oil tube. I forget if e30's have marks on the flywheel, but you can look through the hole in the transmission to see a mark.Comment
AHH right! i knew that... its been a while since i worked on my e30...
remind me again, which way does the engine rotate? you know, turning the pulley by hand, which way do i turn if i were to stare straight at it (front of car looking towards the back).2007 Mazda CX-7 (red TURBO!!)
previous cars
