Hi chefe , can anyone tell me how to conecta the fuel pressure regulateur ? Where is conected the fuel from the pump ? Where is conectar the line from de regulator to the intake ? And where is conected the the returno fuel line ? Sory my english and thank you for any responde that i might have
m10b18i problems
If it doesn't run right after you match this photo, swap the fuel pump lines. You can do it at the fuel pump or at the rail'84 318i M10B18 147- Safari Beige
Turbo: 221whp/214ftlbs, MS3x flex @ 17psi -
Thank you friend , can i hask onde more thing ? The vacum hoae fromthe distribuidor is conected in the intale right ? And the pressure regulatório is conected in the in the intake right ? I dont havê more places to conecta into da intake :( tonight i take photos and posto here for you can ser . thank youComment
Hi friends , here i explain my problems
On this photo is marked where i need help
The red circle is de pressure regulateur right ? Where does it conects ?
The green hose where it conects ?
The yellow circle is the distribuitor vauum hose right ? here does it conect ?
And one more question , along the fuel rail near the gear box is de fuel delivery right ?
Thank you for any responses
Forgot to mension is a m10b18i from 84 european without catComment
