M10 B18 rev limiter with launch control.... how to wire it ?
  • E30 ///Mike
    • Dec 2014
    • 2
    Hi, i have a 1984 318i M10B18 and i bought a Bee*R Rev limiter with Launch Control.
    how should i wire it?
    BMW Power!!!
    ONE PASSION, ONE BRAND: BMW!:)
  • Jaxx_
    • Dec 2009
    • 1880
    You should really give more information in your posts concerning wiring, I had to hunt around to find the schematic for the Bee*R system in order to then dig in the 318 wiring diagram. (I gave you a pass because you're new...)
    The only thing you should be missing is the "crank input" which is a black .5mm wire and a yellow .5mm wire that is at the dizzy and the ignition control module(if memory serves it's the small green box under the glovebox). On the ignition control module the wires are pins 3 and 7 respectively.
    Good luck.
