Alright so I'm at a loss about now, I've searched these forums but still nothing will get it running. About 8 months ago it was running good til just one day it quit on me and never fired up after that.
The engine turns over but doesn't fire. Here is the list of things I've gone through and or replaced..
Checked wires and spark
New fuel filter
New fuel pump
New fuel pump relay
Newish(working) FPR
I then discovered I had cracked intake rocker on #1 so I removed head and replaced with one from my donor m10.
I had read about slop in the distributor shaft and mine had a lot so I replaced it, I have confirmed in getting fuel to the rail but the return. Doesn't stiffen up. I've changed out injectors to others. And it still just turns over.
I'm at a complete loss of what it could be. I've experienced a bad ecu and it still ran with the one that fouled out on me.
You can hear the pump screaming but seems to never build up pressure and cut out. Could this be the cause? Could the in tank pump cause it to completely not start? That would be weird since I am getting fuel to the FPR
Please any help is greatly appreciated I'm not looking for some troll to come bash on me I'm looking for something that will get my car running
Thanks for looking.
New fuel filter
New fuel pump
New fuel pump relay
Newish(working) FPR
Thanks for looking.
