M10 with m30b35 gearbox , bit lost
  • Jayzrb
    • Nov 2016
    • 2
    Just registered on this forum,
    I've used this forum few times and thought I'd register.
    I've searched for forums regarding a gearbox swap into a m10 in a e30.
    The gearbox I have is a g260/6 of a m30b35.
    I know I have to shorten the drive shaft and gear linkage.
    Anything else I need to knw? Like starter , clutch, gearbox mounts.
    The diff I'm using is a medium, LSD
    I have searched but couldn't find anything relevant. So thought I'd just ask.
    Cheers
    Any help will be appreciated
  • kronus
    • Apr 2008
    • 13031
    You can use a 87 big-giubo driveshaft and it'll fit without mods. You can use the shift linkage and mounts from a 325i without mods as well. Starter should match flywheel.
    cars beep boop
