Dead Not at all cranking need help
  • nirenandrews
    • 26
    Hi, friends, I have an e30 with m10 in it, this car ran some 8years back but was left uncared. I got it and I am trying to restore it. the wiring is fine not eaten by rats. the problem is it is not cranking at all and i am not getting any lights in the speedo console. Please help me with a systematic approach, guide me with some instruments that can be used to solve the problem.
  • nirenandrews
    • 26
    i tried the jump start method, connected the starter solenoid directly to battery yet no sound,or crank
    • loki_
      • Sep 2013
      • 147
      So you have a good battery in the car and when you turn the key nothing happens?
      • nirenandrews
        • 26
        yes the battery is good, tried checking the voltage through multimeter. i am using the Bentley manual but i dont know where the real problem is. if you have any systematic approach it will be well appreciated.
        • loki_
          • Sep 2013
          • 147
          ok so when you turn the key the fuel pump doesn't prime and there is no activity on the gauge cluster/radio/headlights/etc?
          • nirenandrews
            • 26
            i get display in the radio, the head light works but no lights in the speedo.
            • loki_
              • Sep 2013
              • 147
              when you turn the key do you hear the fuel pump under the rear seat prime?
