General head machine work question
  • Mr Deagle
    • 1121
    there are no bearings in the m10 head.......well just plain bearings, but they will show some wear
    and duh, what do bearings do? they spin!
    • Jean
      • 18228
      Well, i'll have it back from the shop tomorrow and take some pics then you experts can tell me if I should dump it or not :up:
      • MarshallM
        • Feb 2007
        • 229
        Sonic cleaning will also ensure a perfectly clean head. Improves cooling by getting all the scalies off the cooling passages. You cant magnaflux a aluminum head due to it being non ferrous but you can have them dye it and look for cracks or pressure test.
        • Jean
          • 18228
          Well here it is, what the shop meant is where the cam rotates there is some wear. What do you guys think, toast ?
          Bigger size pictures are here - http://www.briangt.com/gallery/album55
          This is on the distributor side, not sure why the whole on the left side looks like that ?
          • FredK
            • 14761
            Yikes. I'm no expert, but those look like some serious grooves!
            • backtrail69
              • Jul 2005
              • 4471
              That looks pretty scored. It is really hard to tell from the pictures though.
              :: PNW Crew ::
              '87 325 4dr, '74 2002
              • euroshark
                • Apr 2006
                • 3491
                Lack of oil probably did that... I think it's toast.
                • Mr Deagle
                  • 1121
                  buy a schrick 316 cam and bore them out!
                  • Jean
                    • 18228
                    So how would this thing run if I put it back together ? Would it vibrate a lot, be loud or else ?
                    I was hoping to just junk the head I have on the car and install something fresh....now looks like maybe I should remove the head from my car and have it checked / cleaned. This engine will eventually be removed to make room for something else so buying expensive / rare cams etc isn't an option .
                    • Jean
                      • 18228
                      Ok forgot to ask this, someone suggested I ask on the forum. Is there a way to bore the camshalf holes out and fit a bearing in them ?
                      • ivo316
                        • Oct 2006
                        • 1222
                        You have to keep in mind that here sometimes we do not have access to parts, so...
                        Here in Chile machine shops will bore those holes and install thicker bearings, or else, bore the hole and insert a sleeve to accomodate stock bearings, but you will have to resurface your camshaft also, those grooves are too much, I don't know if the total bill for repairing the head plus the camshaft and the new bearings will be less than a used fully assembled head (in good condition), you have to do your adding up and see what's best for you, but since so many people are swapping their engines i think you could find a reasonably priced head (with camshafts) somewhere.
                        Everything can be repaired, but sometimes it's too expensive.
                        Good luck. ;)
                        • Jean
                          • 18228
                          Yep, I decided against it. I MIGHT remove the head I have on the car and have a shop refresh it, now I have some spare valves/rockers/cam in case.
                          Decided not to spend anymore on the m10, gotta start getting m50 parts.
