Overheating...and then some
  • Brinkley
    • 379
    Warning: Complete e30 newb
    Hey all, I've got an 85 318i that im looking to turbo in the future. Right now though it has an overheating problem sitting in traffic that I think is the fault of the fan clutch not spinning very fast at all.
    Now-- I've considered going to the 325 radiator since im going to be going turbo or even doing a swap at some point but id like it to stop overheating for now. Should i:
    Just get the 325 radiator w/ elec fan
    Put elec fan on 318 rad
    Replace clutch fan
    thx all appreciate any help
    I don't think your mom appreciates the value of those modifications
  • Jean
    • 18228
    None of the above.
    Before you start buying parts, flush/refill coolant. Check the clutch fan with newspaper. Thermostat should be your next cheap fix if flushing and clutch fan didn't fix it.
    • Brinkley
      • 379
      hey i appreciate the feedback. ill give that a shot. Been busy making repairs to my e46. Guess it is jealous that i have a new bmw :)
      • Brinkley
        • 379
        let the car warmup in the driveway today it was definitely low on coolant put a fair amount in and noticed that fully warm and at idle clutch fan wasnt spinning at all.
        • AppStateSVX
          • Oct 2005
          • 381
          MRs never overheat......should have kept the 2
          -1992 325i -
          BavAuto Chip
          Tokico Spring/Shocks
          more to come later
          • Brinkley
            • 379
            hahahahah I KNOW thats not true!! have it on video!!!
            • Joe318is
              • Sep 2005
              • 6451
              i wouldnt swap to a larger radiator unless you need to. FI needs to be at the right temp to work properly, too cold could caue issues.
              if it is the fan clutch. swap to an electric set up, its cheaper. find an old mk2 vw in a yard and yank the switch for the electric fan and wire it into the system as the ground. works like a charm
              Originally posted by vlad
              • Brinkley
                • 379
                Thx!! to both of you guys! You've been a great help
                • redbull 325is
                  • 7472
                  omgz hi2u, replace the fan.
                  <3
                  Ju
                  Build Threads:
                  • Borat
                    • Jan 2005
                    • 494
                    would the thermostat not keep the engine at the proper temp?
                    • Brinkley
                      • 379
                      clutch fan replaced idles fine. :) dont even have to turn on da heat
