New fuel pump relay and now fuel pumps run constantly on power accessories mode!
  • alpinewhite318i
    • 134
    I put in a new fuel pump relay on my 84 318i. When I turn on the key to the power accessories mode the fuel pumps run constantly. I know with the older relays when you turned it on to power accessories the fuel pumps would run for just a few seconds. Any help greatly appreciated.
  • k3vunlimited
    • Apr 2021
    • 1
    Hey there I'm having the same issue on the same car!
    I replaced the 7 prong relay closest to front of car and now both pumps staying running when in the on position, and keeps the injectors all spraying at once. I'm chasing a rough start/idle, rich condition, where the spark plugs are wet with gas. Were you able to figure anything out? I am hoping the ecu isn't bad in my case.
    • alpinewhite318i
      • 134
      Yes I did figure it out, these newer fuel pump relays are junk! The parts companies should be contacting the manufacturer because it's dangerous for it to be always running. I just ended up using one of my old fuel pump relays and the issue went away!
