Hey all, I need some guidance. Everything bolted back in car and started on the pre start checklist. First of being priming oil pump. Installed drill and six mm socket. Removed power from fuel system and cranked on drill. 0 psi at guage. Removed oil filter and cranked again. Plenty of oil coming from block.
removed the adapter for turbo oil feed and removed oil pressure sending unit. Verified gauge. Cranked drill again and have no oil coming from the m12 hole at all. What gives? Did I miss something?
remote mount filter and cooler also if it make a diff
