M20 2.5L performance build
  • ADEN
    • 620
    Originally posted by dvallis
    You either do an optimized NA build with the headers etc. or do a turbo build. Not both.
    If you're a reasonably proficient Wrench, piecing together a turbo setup is not hard. Lots of examples on here. Otherwise, a kit is the way to go. Don't use a huge turbo. Smaller is better. Check the turbo map and size it to M20 flow.
    We had a lot of success with Megasquirt plus MAP.
    I am interested in the smaller turbo idea but need to know the smallest turbo i can use @ 6k or even 5.5k RPM without causing bad exhaust restriction?
    • dvallis
      • Oct 2015
      • 1474
      So, it's not about exhaust restriction. You need to use a turbo properly sized for the expected boost and flow CFM of an M20. Read up on Turbo Maps.
      We're using a Garrett GT3076R T4 0.63 A/R turbine, 0.60 A/R compressor, ball bearing CHRA, water/oil cooled. Not cheap but bullet proof.
      Specs are here. Including the turbo map.
      "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
      1987 E30 3L Turbo Stroker Das Beast
      2002 E39 M5
