325i m20b25 automatic need help
  • Envy My E30
    • 13
    i bought a 325i m20b25 its been hit no worries about that the car runs great except n all theres just one problem that bugs me. the problem is when i push it up to 4k rpm and keep it steady then it will drop from 3k rpm back to 4k rpm then it will shift. im thinkin it might be from my spark plugs or wires or something or my tranny... someone guide me through please.
  • ADEN
    • 620
    when it drop to 3k rpm does it shift gear?
    • Envy My E30
      • 13
      ya it shifts fine, it just wiggles a bit before shifting let me no if that makes it more clear(this only happens when i push it)
      • ADEN
        • 620
        you may need to have your tragmatic (LOL automatic)transmission cable adjusted 13'' wrench.if you do NOT know how to adjusted i advise to let someone pro. do it for you.
        • Liam
          • 753
          Are you two speaking English?
          OP:
          Can you rephrase the question (explain a little about what is happening)
          What does the trans fluid look like?
          I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃xS : φ(x)) → (∀xS : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
          • SpecM
            • Oct 2005
            • 4531
            also, is the fluid level even full? does the engine run well otherwise?
            1989 cirrisblau-metallic 325i
            • Envy My E30
              • 13
              which tranny cable r u talkin about?
              • Envy My E30
                • 13
                my tranny oil pan gasket leaks but ive been watchin the level to make sure its full
                • ADEN
                  • 620
                  the tranny cable connected to the throttle body.
