fan hitting rad
  • new2bmw
    • Oct 2006
    • 387
    fan hitting rad
    the only reason i have heard of this happening is engine mounts are gone. how do you go about checking that? please use detail lol, im new to this. also , any other reason the fan may be hitting? I think this may be the only really big problem with the engine in this car.
    cheers and thanks
    Larry
  • gazellebeigem3
    • Jun 2005
    • 3712
    easiest at home/limited tools way would to put a wood block on a floor jack and put some pressure on the oil pan. It should be pretty obvious, and most likely the passenger side.
    • E30Eric
      • Sep 2007
      • 156
      Make sure your fan shroud is not cracked also. My fan contacted the shroud and snapped three blades off including one into my new rad while i was in traffic on the highway.... I now have ditched it for an electric fan on it's own circuit...
      1988SuperETA|Full I component swap|19lb injectors|Schrick 272|MSIIExtraBeta20071020|GM DIS Wasted Spark|LC-1
