Do SpecE30 racers break a lot of rocker arms?
    Seems like they would... right?
    I'm considering a 325i for a track car, but don't want to get into replacing rocker arms all the time. I'd rather get an M42 car instead if that's going to happen.
    spec e30 is doing away with the m42 i heard over on m42club
      Just use good new rockers when you put the engine together and don't rev the holy piss out of it and they'll be fine.
      I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃xS : φ(x)) → (∀xS : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
        I was thinking that they would break by virtue of the fact that they're being revved hard all the time --- driven hard around the track, constantly between like 4k and 7k RPM --- lots of RPM all day long.
        No?
        Are they just prone to breaking nowadays because most M20's have high-mileage?
          No?
          Pretty much, (unlike steel) aluminum only lasts so long under stress.
          And I would also venture a guess that a lot of knuckleheads are over torquing the adjuster nuts and are pre fucking them so they fail.
