Lately I have been having some trouble getting my 85 325e to start right, and now it just won't start. I know the problem is related to fuel. For the last couple weeks I have had to let the fuel pumps run for a bit (leaving key in 'on' position) before trying to start the car and it would start. Yesterday the car started and right when I started driving it died. So, I pulled the fuel pump relay and jumped it as described in repair manual to make sure both fuel pumps were running. By listening to them they both seem to be working. However, I don't seem to be getting any fuel to the engine because it won't start. Is there a better way to test the fuel pumps and/or the relay? I don't want to just start guess buying all new parts for it. Thanks in advance for any assistance.
This is the current situation: Ok so I just pulled the line going into the fuel rail and did a couple tests with it. When I turn the key to the 'on' position (which I think should start the fuel flowing) there is no fuel going to the rail which is why the car isn't starting. Next what I did was pull out the fuel pump relay, and with a wire jump from pin 30 to 87 which should kick in the fuel pumps. When I do this, the fuel starts flowing to the fuel rail. I don't think the relay is at fault because I switched it with the relay to the right of it (main relay?) which had the same part number and still nothing. When I bypassed the fuel pump relay I can hear the main fuel pump going loud, but (without taking the cover off and only taking the rear seat out) I can barely make out the sound of the transfer pump. Could this indicate that the transfer pump is bad? Also, with the key in the 'on' position, should I be able to hear the fuel pumps going? (because i don't).
