I have a 1990 325is. The car has 46000 miles, and the main problem is that the idle is rough, the car sputters occasionally when pulling away from a stop (especially when the car has been sitting), and it hesitates a little at 4000-5000 rpm. The only modifications are a high flow filter, mark d chip (17-19), 19lb. ford injectors, and a stromung exhaust. The car idled rough from the beginning with the mark d chip and injectors, but seemed to get better after a couple days. A couple weeks later, I noticed that the car was sputtering and hesitating a little when pulling away from idle, I thought it was bad fuel. I had it taken in for alignment and got a valve adjustment and new valve cover gasket the same day. The car came back with even worse, shakey idle and a hesitation in the mid-high rpms as well. A lot of the intake rubber components are new, and the fpr was just replaced. I chekced the voltage on the icv and it was within factory specs. I'm 99% sure its not a vacum leak, I suppose there is a chance I could be wrong though. The chip says 17 on it, but I think there is only one mark d chip for 17-19lb. injectors. I feel like the car is a little rich at idle. Any thoughts? Does it sound like over-sized injectors, faulty software, a vacum leak, a weird valve adjustment, or something else? I've been considering a mchenry chip with m50 pre vanos injectors as an alternative. Thanks for the help
Richard
Richard
