D'oHH!
  • TexasE30
    • Jan 2009
    • 298
    D'oHH!
    I just stripped the bolt in oil pan plug. The half of it is in the pan, I really doesnt want go through hassle to remove the half of the plug. Its possible for me to just remove oil pan very slighty enough to remove gasket and plug then bolt them back up with new gasket without take whole thing out?
    Thanks for advice :)
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    prolly won't be able to get yer hand in thur
    -Andy
    • Philo
      Ich esse kleine Kinder
      • 3334
      Drill and easy out?
      -tim
      Originally posted by Jordan
      I like the stance
      • gtdragon980
        • Jun 2008
        • 1808
        i really doubt you're gonna be able to do that and to get that new gasket on is gonna be a bitch because of the pump..you're gonna need to remove the whole pan then imo
        FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
        Originally posted by scabzzzz
        I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
        1989 325i - Project/weekend driver
        2002 325i - DD
        2005 Suzuki SV650 - Toy
          An easy out will remove the remains of the plug. If the threads in the pan are damaged, that can be fixed with a Timesert w/o dropping the pan.
          • TexasE30
            • Jan 2009
            • 298
            threads in the pan is not damaged, the plug is broken in the half. i was thinking about dropping oil pan slightly and use magent to pull another half out. then figure out a way to get gasket around the pump..OH well, I guess Tomorrow will be dirty job for me.
            Thanks everyone tho
              Assuming an OE drain plug, the part that is still in the pan is hollow and will accept an easy out. Try that before dropping the pan.
              If you have to drop the pan you have two choices. You can support the engine and drop the subframe to gain access to the pan or you can disconnect the motor mounts and lift the engine.
              • AlarmedBread
                • Sep 2006
                • 1510
                + 1 to what's been said.
                Try to get it out, but if you can't, dicking around like you are thinking of doing is tougher than dropping the pan and fixing it on the bench.
                • TexasE30
                  • Jan 2009
                  • 298
                  screw this, Im going to jbweld this and force myself to get m50 swap by end of 3 months..
                  wish me luck :)
                  • wagonizzle
                    • Sep 2006
                    • 443
                    wish me luck :)
                    Haha that's awesome. Good luck, man! :up:
                    Originally posted by chileelky
                    amaze about the enthusiasm e30 generate
                    • Kingb
                      • 928
                      So your going to JBweld the whole drain??
                      Originally posted by Nicademus
                      My car beats off to that car. :bow:
                      • TexasE30
                        • Jan 2009
                        • 298
                        nope I just found out that the half of the plug is still inside the pan but it havent fell off and its not loose in pan. I will just use my old plug and twisted it in then jb around that.
                        Then starting collecting stuffs for m50 swap. I have 3 months time-frame :)
