Before you run out and throw more parts at the car, do a quick check. Swap the two temp sensor leads on the thermostat. One is the Coolant temp sender for the ECU (two contacts within the housing) and should have the blue (black) connector. The other is the temp sender for the gauge (single contact within the housing) with the brown connector. It is quite easy to plug them in backwards if you were putting everything together for the first time. If you had them backwards, the very next time you start the engine, the CEL should go out.
As far as the brake lining light, there are two sensors on the car. One on the Driver's front, and the other on the passenger rear. (Could be completely backwards here.) The sensors mount in the pads and close the circuit when they make contact with the rotor. It is not uncommon for the sensor leads to become freyed and short against other areas of the chasis. This will also trip the warning lamp. If your pads are good, check the wiring for the sensor. Odds are that's all that has happened.
