Oil leak - what part is this and how do i fix it? (pic)
  • eek142
    • Apr 2009
    • 78
    I just bought a 1989 325i and am starting to fix it up. I noticed it had a small oil leak while running in the garage today. I wiped everything down on the underside of the car then jacked it up while it was running. Here is the camera phone pic I took:
    As you can see, it's near the oil filter, but the oil filter itself seems fine. What is that part and how do I fix the leak?
  • TheB1G Lebowski
    • 593
    Is there a snap ring holding it in? If so remove the ring with snap ring pliers, and remove the plug. See if you can use a small amount of sealant (silicone) but very very little. Obviously there is oil in there so you dont want any sealant entering the oil lines, or where it routs in the engine. Try to get a clearer pic, and closer with some light too please. And ill look at mine.
    1989 325i - sold
    1987 RX-7 Turbo II - sold
    1990 325i
    • TheB1G Lebowski
      • 593
      Just tried looking at mine and damn how did you get a camera near there? lol. damn that is a tight spot, let me get a flash light and let my engine cool down so i can get my face near it.
      1989 325i - sold
      1990 325i
      • Aptyp
        • 6584
        it's oil thermostat, and they are notorious for leaking. Luckily replacement seal kit is only about $5 from dealer.
        • TheB1G Lebowski
          • 593
          awesome, while i was looking at mine it seems like its leaking too. :(
          1989 325i - sold
          1990 325i
          • eek142
            • Apr 2009
            • 78
            That sounds awesome. I am VERY glad to hear that.
            And yeah, it was a freaking tight spot..had to take the wheel off and really crawl under there.
            • eek142
              • Apr 2009
              • 78
              BUMP for a quick question. I ordered the kit with the new o-ring from Pelican. Is it absolutely necessary to have a c-clamp to disassemble and reassemble the thermostat correctly? I can't find one at the moment and don't want to waste time driving half an hour to the hardware store tomorrow morning.
                I won't say that it is essential, but you'll need three hands to get the spring clip back in otherwise.
                • eek142
                  • Apr 2009
                  • 78
                  Gah. Yeah, no one else is around, so I guess I'm going to have to get the clamp early tomorrow then. Would a 3-inch one be big enough or is 4 inches the minimum? I think that's what was recommended in a writeup somewhere.
                  • SamE30e
                    • Sep 2007
                    • 4319
                    If it's anything like the M50 oil stand, you need to replace the o-ring behind it.
                    1985 325e 2.8 Turbo VEMS
                    • eek142
                      • Apr 2009
                      • 78
                      Just bought a 3" c-clamp b/c they did not have anything bigger. Will this work?
                      • StereoInstaller1
                        GAS
                        • 22679
                        NO!
                        -as a matter of fact-
                        FUCKING NO!
                        this is NOT a goddamn Chevy or Ford, this is a BMW, you do NOT fix leaks like that! No bullshit repairs!
                        Replace the damn crush washers. There are 2 different sizes, just buy both. New o-rings too, plus get the ones at the oil cooler itself, save yourself the hassle. Don't forget you will need a filter and fresh oil. BMW or Mann filter: Walmart 20w-50 high mileage oil.
                        If you can take that photo, you can pull the entire oil cooler system out in about half an hour.
                        Luke
                        Closing SOON!
                        Thanks for 10 years of fun!
                        • SamE30e
                          • Sep 2007
                          • 4319
                          What!
                          That wouldn't work at all, or be smart, the o-ring is like .50$ at Part Source.
                          • eek142
                            • Apr 2009
                            • 78
                            I fixed this today by installing a new snap ring, plug, and o-ring. Getting the new snap ring in was a huge pain in the ass given the lighting, room to work, and a slippery c-clamp.
                            • M-technik-3
                              • 18946
                              Suggest using some better filters.
