Is it possible to change the seals in my power steering rack or do I have to buy a whole new rack? 1990 325i, stock rack. I know, I know, wrong section, but this section seems to have more viewers. Thanks!
power steering question
Rebuilding a rack would be more time consuming and prob more expensive than replacing it as a whole unit. I would think the seals would be hard to find and expensive. Mine is leaking too, but through the passenger side boot. But the leak hasnt been too bad, a lil splash of p/s fluid once every week, week and a half. Me if it isnt leaking bad i would let it ride for a lil while.1989 325i - sold
1987 RX-7 Turbo II - sold
1990 325i -
Mine is leaking through the passenger side too, but POURING out the boot. I would fill the resevior, and after 2 or 3 turns it will be empty. I can see a trail of fluid when I drive after I fill it. I wouldnt know where to get the seals either, or how to change them. I was thinking/hoping they would pop it and out like a front/rear main seal but I am not sure, never did one before.Comment
The seals on the rack wouldnt need servicing seal wise, its basically shot and needs to be replaced. For the time being until you can replace the whole unit get a new boot to at least contain the fluid so it wont be leaking. I tried using black silicon to patch it up but wasnt too successful with it holding well.1989 325i - sold
1990 325iComment
So its still leaking with a good boot and a clamp?1989 325i - sold
1990 325iComment
Heres a sweet DIY on replacing the e30 with a e36 rack. Gives you a better turn to lock ratio. http://r3vlimited.com/board/showthread.php?t=662471989 325i - sold
1990 325iComment
Ok i would have to say it would contain the leak.1989 325i - sold
1990 325iComment
"God created turbo lag to give V8's a chance" Taylor D.
Rebuilding a rack would be more time consuming and prob more expensive than replacing it as a whole unit. I would think the seals would be hard to find and expensive. Mine is leaking too, but through the passenger side boot. But the leak hasnt been too bad, a lil splash of p/s fluid once every week, week and a half. Me if it isnt leaking bad i would let it ride for a lil while.Comment
1987 325is
--- used to haves ---
1988 325is
1999 540i/6/Sport
1989 325iX
1998 M3Comment
