How reliable are e30 cooling systems? Questions...
  • eek142
    • Apr 2009
    • 78
    Just bought an '89 325i and I'm in the middle of fixing a few things up. Do e30's undergo expansion tank failures like the e46? What about the OEM water pump? All hoses are new and the radiator looks okay. At this point, I'm just trying to do some preventative maintenance on cooling system parts that would lead to catastrophic damage/engine overheating.
  • bostonbmw
    • Nov 2004
    • 429
    The E30 cooling system is robust and does not have any common failures like e36. All the water pumps are metal as well as the thermostat housing. I have never had a problem with my expansion tank 7+ years.I have had a problem with the cork gasket for the throttle body heating line, it wont leave you stranded but it will let a small amount of coolant leak. I would make sure your clutch fan is working properly and that the Aux fan HI and Low positions are functioning properly. If you push the ac button the aux fan should turn on the LOW setting. It should automatically turn on the High setting once the coolant gets to a certain temp.
    • eek142
      • Apr 2009
      • 78
      Great. Yeah, i guess a metal impeller in the water pump is a huge advantage. If it's on it's way out, would it probably make noise instead of just shredding apart like a plastic one?
      • Hallen
        • 1008
        Yeah, the expansion tanks are fine on this car. It isn't mounted to the side of the radiator like the E46 is. The water pumps are good, but should be replaced periodically anyway. Other than that, it is just the normal things.
        1987 E30 325is
        1999 E46 323i
        RIP 1994 E32 740iL
        oo=[][]=oo
        • e30slut
          • May 2008
          • 793
          i remove th coolant lines to the throttle body.. is that a bad ting?
          • SpecM
            • Oct 2005
            • 4531
            nah, its probably a good think
            Maybe 10% of e30s still have them connected
            1989 cirrisblau-metallic 325i
            • eek142
              • Apr 2009
              • 78
              Only if you accidentally the whole thing.
                In my opinion any cooling system that has plastic parts in the radiator and/or expansion tank needs for those parts to be replaced no less often than every 8 years or 120k. Heat causes plastic to become brittle and total failure of the cooling system can result in repairs that pale in comparison to the cost of those parts.
