Carburated M20?
  • vr2jetta
    • 460
    Carburated M20?
    I found a carb and intake manifold for an M20 and was wondering if this was a stock setup on earlier cars. Has anybody ran this? What are your thoughts? I am starting to get fed up with these FI issues and if I cant find a solution soon I may just pick it up.
  • kronus
    • Apr 2008
    • 13032
    Yes, earlier M20's were carbed. Running a carb is not a solution to FI issues.
    cars beep boop
    • Slangbox
      • Jan 2009
      • 599
      What??
      *Mind exploding*
      Body roll+perspective=the poor man's drop
      • vr2jetta
        • 460
        It could be for me! I cant seem to get my car to run right. I just put a new head on along with $500 in other parts and now the thing wont rev past 2k. It was throwing a coolant temp sensor code so that was changed. The plug under the intake was corroded so it was cleaned and tightened up and still, no rev. The computer was throwing a coolant temp code still, so I pulled all the grounds and cleaned them up along with replacing one. I re-connected the battery and still, no rev. Now the CEL is telling me no fault codes in memory....1444. I have ordered a used DME to see if thats the problem but if that dont fix it, I am out of ideas.
        • kronus
          • Apr 2008
          • 13032
          Basically, the idea is that if you can't troubleshoot a FI system, you will not get a carbed M20 to run right.
          cars beep boop
          • Justin B
            Sikky Nar Nar
            • Mar 2005
            • 4273
            triple webers! ha, tru dat though, kronus. 3 DCOE's would be an absolute nightmare.
            • Slangbox
              • Jan 2009
              • 599
              wtf carbureted???
              *mopping up brain tissue*
              • vr2jetta
                • 460
                I had enough trouble keeping 2 delortos tuned on my 8v gti so 3 DCOE's would be hell. I've had plenty of carbed VW's and they ran great, just asking for some opinions on BMW carbs........thats all.
                • Slangbox
                  • Jan 2009
                  • 599
                  *All remnants of life sucked through a giant venturi*
                  • Justin B
                    Sikky Nar Nar
                    • Mar 2005
                    • 4273
                    I understand. Kind of halfway joking, as it was one of my original ideas before I've stubbornly decided to put ITB's on my stroker build. One thing about that M20 carburetor manifold, I believe it would have been from an early M20B20, so the intake ports would not match at all to your B25's without a lot of port work.
                    • vr2jetta
                      • 460
                      Originally posted by Slangbox
                      What??
                      *Mind exploding*
                      wtf carbureted???
                      Boy, you are full of facts and helpful information.
                      • kronus
                        • Apr 2008
                        • 13032
                        I think he's tripping on acid.
                        cars beep boop
                        • vr2jetta
                          • 460
                          I am no stranger to port work, done plenty so that wouldnt bother me too much. Ive found a few threads that had mentioned that also. I have also heard there are adapter plates available to use holleys, and weber possibly made a direct replacment for that manifold.
                          • vr2jetta
                            • 460
                            No, he's just some dumb punk kid that doesnt really know anything but wants to feel involved in the car community.
                            • Farbin Kaiber
                              Lil' Puppet
                              • 29502
                              "So, I cannot make the electronic FI system function properly, so I'm gonna slap a carb on there. "
                              Sounds like a domestic guy.
