If you are upgrading your ECU to Motronic 1.3, the stock "e" 18# injectors will not work. They are low inpedance and you need the high impedance ones. FWIW, the eta FPR is 2.5 bar, and the i is 3.0 bar. Given the difference in fuel pressure between the two, they flow aproximately the same.
