Intermittent bucking problem
  • slo325i
    • 417
    Hey guys,
    After searching for hours and hours... i've yet to find out the problem.
    Now, let's figure out a diagnosis:
    Patient info
    1987 325 with m20b27 eta motor
    Sign and symptoms:
    1. Intermittent bucking/jerking when I take off normally from a light
    2. Intermittent bucking/jerking while cruising on hwy in 5th gear
    3. Fuel economy/econometer gauge jumps left and right as the motor "pauses" which I think is causing the bucking/jerking.
    4. No CEL light.
    Interventions done:
    1. Distributor cap
    2. Rotor
    3. coil
    4. spark plugs/wires
    5. crank position sensor
    6. fresh oil
    7. new battery with new ground cable
    8. fuel pump relay
    9. fuel pump (under the back seat)
    10. alternator
    11. Sprayed/brushed/lubed all connections
    (coolant sensors, CPS, injectors, TPS, relays)
    12. FPR (brand new)
    Interventions not done yet:
    1. Fuel pump under the driver seat
    2. O2 sensor
    3.
    4.
    I'm really lost as to why my car's having these intermittent issues. And when I say intermittent, it really is... only happens 4~5% of the time while driving. It's not on constantly at all. I just got back from 5 hour drive with this car and it was a fantastic ride, smooth and everything... It's just when i take off from 1st gear, it bucks/jerks/pauses around 2000rpms. After that it's smooth sailing...
    Please help.... Running out of ideas :neutral::neutral::neutral:
    Justin
    '89 325i - Totaled... good bye my love...
    '87 327i budget stroker - SOLD!!!
    '92 240sx - ca18det powered drift toy - SOLD!!!
    '89 325i - coupe - NEW daily
    '96 Audi A6 Quattro- Grocery getter/baby hauler
    '99 Busa - weekend wheelie monster
  • vr2jetta
    • 460
    Ahhhh, the infamous 2k bucking problem. I have been having issues with mine too. I have noticed on mine it only does it when I fill the tank. After it gets past 3/4 it drives fine. My fuel pump has started whining louder lately so I am guessing that is going to be the culprit. For good measure I also ordered a new DME relay and fuel pump relay. Good luck with that.
    • slo325i
      • 417
      anyone else??
      I've also replaced the main relay. My fuel pumps don't whine at all , that's why i haven't felt the need to replace the pump under the driver's seat. I'll try to get a gauge to see what fuel pressure's like though...
      Please help...
      Justin
      • che13
        • Aug 2004
        • 217
        MAF - could be the culprit
        • slo325i
          • 417
          Oh yea... replaced that too... as well as the throttle body and TPS
          • slo325i
            • 417
            Could it be related somehow with my fuel/econo gauge??
            Because when the car jerks, so does the econo gauge.
            Anyone??
            • yert315
              • 2734
              Have you tried swapping in another ecu or checked your coolant temp sensor?
              • slo325i
                • 417
                About the coolant temp sensor, exactly which one is it? Is it the brown one with a single wire or the blue one with two wires attached? I've cleaned, and lubed connections there as well. I do have bunch of spare sensors though.
                Also, currently, i'm running a 153 ecu. I have a spare 173. Should I try swapping it or not? i dont' want to cause any damages though. I hear it's actually a direct bolt-on upgrade. but i'm not too sure...
                • vr2jetta
                  • 460
                  Coolant temp sensor is the blue one, the brown one goes to the gauge.
                  • yert315
                    • 2734
                    it's the two wire one, like vr2jetta said. give it a shot if you have an extra.
                    also, I'm not that familiar with the eta motors, but I do not think the "i" ecu will work with them. If you can source out another eta ecu, that would be your best bet.
                    • slo325i
                      • 417
                      the 153 ecu's a 87 325i ecu. Which rev'ed a little lower than the 173 ecu's which came out on later 89 325i.
                      • slo325i
                        • 417
                        To make the long story short, the PO installed an eta motor in the 325i motronic 1.3 harness with the 153 ecu. I dunno how he ghetto fabbed it together but it runs really well other than the bucking symptom at hand. I mean, i heard that the eta injectors were high impedance whereas the i injectors were low impedance. I guess he swapped out the injectors too because like i said, the car runs really well.
